explorations
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
desvarlist
The list of associated design variables.
Type: entity array
desyncflag
Flag to mark an evaluated exploration as desynchronized from its results, if its design variables or responses data are modified. Valid for hm_getvalue query only.
Type: Boolean
explorationlabel
The label, used for the approach folder name.
Type: string
explorationtype
1 - Design of experiments
2 - Optimization
3 - Verification
Type: integer
explorationtypename
The name of the exploration type. Valid for hm_getvalue query only.
Type: string
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
internalname
The internal name of the entity.
Type: string
isactive
True if the exploration is active. Valid for hm_getvalue query only.
Type: Boolean
location
The location of the exploration.
Type: string
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
optimizationname
The name of the optimization. Valid for hm_getvalue query only.
Type: string
optimizationtype
1 - Gauge optimization
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
parentid
The ID of the parent exploration. Used for DOE/optimization verification runs.
Type: entity
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
responselist
The list of associated responses.
Type: entity array
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
studyid
The ID of the study where the exploration is defined.
Type: entity
varname
The name of the variable. Valid for hm_getvalue query only.
Type: string
Version History
2020
2020.1 - Added new data name solverkeyword.
2021 - Added new data names desyncflag, explorationlabel, parentid and studyid.
2021.1 - Added new explorationtype value 3 and new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
