results
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
combinationfile
The name and path of the combination file.
Type: string
config
The configuration of the entity.
currentstep
The current subcase and simulation IDs.
Type: string
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
evnEqns
Used to create envelope equations.
Type: string
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
init
Initialize and generate the hierarchy for the given modelfile, resultfiles and combinationfile.
Type: Boolean
internalid
internalname
The internal name of the entity.
Type: string
LspEqns
Used to create linear superposition equations.
Type: string
model_fileid
The list of file IDs assigned to modelfile in the same order.
Type: string
modelfile
The name and path of the model file.
Type: string
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
resourceeditfiles
The list of file paths which are used while adding/removing resource from the result entity.
Type: string
resourceeditmode
The resource edit mode. Used in conjunction with the resourceedifiles data name for the purpose of adding/removing resources from the result entity.
Type: string
resourcelist
The resource IDs present in the result entity. Valid for hm_getvalue query only.
Type: entity
result_fileids
The list of file IDs assigned to resultfiles in the same order.
Type: string array
resultfiles
The names and paths of the result files.
Type: string array
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
subcasecount
The number of subcases in the result entity. Valid for hm_getvalue query only.
subcaselist
Subcase IDs present in the result entity. Valid for hm_getvalue query only.
Type: entity
virtual_fileids
The list of virtual file IDs of derived subcases from evnEqns and LspEqns.
Type: string array
Version History
2019.1
2020 - Added new data name color_rgb.
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names currentstep, internalname, resourceeditfiles, resourceeditmode, resourcelist, solvername, subcasecount, and subcaselist.
