members
Unless otherwise specified, data names are accessible in level 3 only.
- _baseFlags
- The base flag of the entity.
- _representations
- The representations of the entity.
- _representations_functionalrepresentation
- The functional representations of the entity.
- _representations_geometricrepresentation
- The geometric representations of the entity.
- _representations_solverrepresentation
- The solver representations of the entity.
- _subType
- The sub type of the entity.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- config
- The configuration of the entity.
- controllocations
- A list of 3D co-ordinates that define the member. Each co-ordinate is a triple of type double.
- definedentity
- True if the entity is defined, false otherwise.
- endmemberjoint
- The ID of the member joint at the end.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- internalname
- The internal name of the entity.
- membersections
- The list of member sections contained in the member.
- membersegments
- The list of member segments contained in the member.
- moduleid
- The module ID of the entity.
- name
- The name of the entity.
- numcontrollocs
- The number of control locations of the member.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- poolid
- The pool number of the entity.
- poolname
- The pool name of the entity.
- primaryrepresentation
- The current representation of the panel.
- solver_id
- The solver ID of the entity.
- solverkeyword
- The name of the solver keyword.
- solvername
- The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
- startmemberjoint
- The ID of the member joint at the start.
- symmetryid
- The plane entity if panel was created from a symmetry.
- symmetryparent
- The ID of the parent member panel used for symmetry.
Version History
2022
