boxes
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
 - Returns non-zero if the entity is set inactive, 0 otherwise.
 - ars_fr
 - Defines a radius of curvature to smooth discontinuities between adjoining straight-line segments, adjoining circular-arc segments, and adjoining straight-line and circular-arc segments.
 - ars_maxratio
 - The upper bound of the ratio of a facet's contact thickness to its minimum edge (or diagonal) length.
 - ars_scalethick
 - The amount by which to scale the thicknesses of the underlying elements to compute the contact thicknesses.
 - ars_trim_value
 - Invoke trimming of open free surfaces.
 - ars_types
 - The surface type:
 - attributesmax
 - The number of attributes owned by this entity.
 - box_corner1
 - The minimum corner points of the box.
 - box_corner2
 - The maximum corner points of the box.
 - box_corner1_x
 - The minimum x-corner point of the box. Valid for hm_getvalue query only.
 - box_corner1_y
 - The minimum y-corner point of the box. Valid for hm_getvalue query only.
 - box_corner1_z
 - The minimum z-corner point of the box. Valid for hm_getvalue query only.
 - box_corner2_x
 - The maximum x-corner point of the box. Valid for hm_getvalue query only.
 - box_corner2_y
 - The maximum y-corner point of the box. Valid for hm_getvalue query only.
 - box_corner2_z
 - The maximum z-corner point of the box. Valid for hm_getvalue query only.
 - box_corner_node1
 - The node defining minimum corner points of a box.
 - box_corner_node2
 - The node defining maximum corner points of a box.
 - box_system
 - Local coordinate system of a box.
 - color
 - The 1-64 color of the entity.
 - color_rgb
 - The RGB color of the entity.
 - config
 - The geometry type configuration of the entity.
 - crop_orient_a_x
 - The x coordinate of the lower box corner. Valid for hm_getvalue query only..
 - crop_orient_a_y
 - The y coordinate of the lower box corner. Valid for hm_getvalue query only.
 - crop_orient_a_z
 - The z coordinate of the lower box corner. Valid for hm_getvalue query only.
 - crop_orient_b_x
 - The x coordinate of the opposite box corner. Valid for hm_getvalue query only.
 - crop_orient_b_y
 - The y coordinate of the opposite box corner. Valid for hm_getvalue query only.
 - crop_orient_b_z
 - The z coordinate of the opposite box corner. Valid for hm_getvalue query only.
 - cylinder_base_node
 - Base node of the cylinder.
 - cylinder_base_point
 - Base point of the cylinder.
 - cylinder_base_x
 - Base point x-coordinate of the cylinder. Valid for hm_getvalue query only.
 - cylinder_base_y
 - Base point y-coordinate of the cylinder. Valid for hm_getvalue query only.
 - cylinder_base_z
 - Base point z-coordinate of the cylinder. Valid for hm_getvalue query only.
 - cylinder_diameter
 - Diameter of the cylinder.
 - cylinder_direction_node
 - Direction axis node of the cylinder.
 - cylinder_direction_point
 - Direction axis point of the cylinder.
 - cylinder_direction_x
 - Direction axis x-point of the cylinder. Valid for hm_getvalue query only.
 - cylinder_direction_y
 - Direction axis y-point of the cylinder. Valid for hm_getvalue query only.
 - cylinder_direction_z
 - Direction axis z-point of the cylinder. Valid for hm_getvalue query only.
 - definedentity
 - True if the entity is defined, false otherwise.
 - gen_pointa
 - The global coordinates of point a.
 - gen_pointb
 - The global coordinates of point b.
 - gen_pointc
 - The global coordinates of point c.
 - global_a_x
 - The global x coordinate of point a. Valid for hm_getvalue query only.
 - global_a_y
 - The global y coordinate of point a. Valid for hm_getvalue query only.
 - global_a_z
 - The global z coordinate of point a. Valid for hm_getvalue query only.
 - global_b_x
 - The global x coordinate of point b. Valid for hm_getvalue query only.
 - global_b_y
 - The global y coordinate of point b. Valid for hm_getvalue query only.
 - global_b_z
 - The global z coordinate of point b. Valid for hm_getvalue query only.
 - global_c_x
 - The global x coordinate of point c. Valid for hm_getvalue query only.
 - global_c_y
 - The global y coordinate of point c. Valid for hm_getvalue query only.
 - global_c_z
 - The global z coordinate of point c. Valid for hm_getvalue query only.
 - id
 - The ID of the entity.
 - include
 - The ID of the include file the entity is organized in.
 - includeid
 - internalid
 - internalname
 - The internal name of the entity.
 - moduleid
 - The module ID of the entity.
 - name
 - The name of the entity.
 - no_offset
 - Returns true if this surface will ignore the midplane offset of any shell, membrane, or rigid elements that form the surface.
 - no_thickness
 - Returns true if this surface will ignore the thickness of any shell, membrane, or rigid elements that form the surface.
 - orienta_pointa
 - The coordinates of the lower box corner.
 - orienta_pointa
 - The coordinates of the opposite box corner.
 - Orientation
 - Returns true if defining coordinates of first and second point orientation.
 - outputsuppressed
 - Returns non-zero if the entity is set "do not export", 0 otherwise.
 - poolid
 - The pool number of the entity.
 - poolname
 - The pool name of the entity.
 - preservenodes
 - Returns true if the box corner nodes are to be preserved, false otherwise.
- region_type
 - Relevant for surfaces defined on the boundary of an adaptive mesh domain.
- segment_datalines
 - Subsequent data lines define the various line, circular, and parabolic segments that form the profile of the analytical surface.
- segment_p1_x
 - The x coordinate of end point 1.
- segment_p1_y
 - The y coordinate of end point 1.
- segment_p2_x
 - The x coordinate of end point 2.
- segment_p2_y
 - The y coordinate of end point 2.
- segment_start_x
 - The local r coordinate of the starting point of the line segments.
- segment_start_y
 - The local z coordinate of the starting point of the line segments.
- segment_table
 - The table defining the line, circle and parabola to form a cylinder and revolution.
- segment_types
 - The line, circular, and parabolic segments that form the profile of the analytical surface.
- solver_id
 - The solver ID of the entity.
 - solverkeyword
 - The name of the solver keyword.
 - solvername
 - The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
 - sphere_center_node
 - Center point node of the sphere.
 - sphere_center_point
 - Center point of the sphere.
 - sphere_center_x
 - Center point x-coordinate of the sphere. Valid for hm_getvalue query only.
 - sphere_center_y
 - Center point y-coordinate of the sphere. Valid for hm_getvalue query only.
 - sphere_center_z
 - Center point z-coordinate of the sphere. Valid for hm_getvalue query only.
 - sphere_diameter
 - Diameter of the sphere.
 - Surface
 - Create a new surface that will contain only those faces from an existing surface that have nodes in a specified rectangular box.
Version History
2020 - Added new data names ars_fr, ars_maxratio, ars_scalethick, ars_trim_value, ars_types, color_rgb, crop_orient_a_x, crop_orient_a_y, crop_orient_a_z, crop_orient_b_x, crop_orient_b_y, crop_orient_b_z, gen_pointa, gen_pointb, gen_pointc, global_a_x, global_a_y, global_a_z, global_b_x, global_b_y, global_b_z, global_c_x, global_c_y, global_c_z, no_offset, no_thickness, orienta_pointa, orienta_pointb, orientation, region_type, segment_datalines, segment_p1_x, segment_p1_y, segment_p2_x, segment_p2_y, segment_start_x, segment_start_y, segment_table, segment_types and surface.
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
