seamexcitations
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
APPLIEDLOAD_VARIABLE
The type of reverberant applied load.
101250 - Acceleration
101251 - Velocity
101252 - Displacement
101253 - Pressure
Type: unsigned integer
attributesmax
The number of attributes owned by this entity.
BANDWIDTH_TYPE
The frequency bandwidth type of excitation load.
101256 - One Third Octave
101257 - Octave
101258 - Logarithmic
101259 - Linear
CASE_NO
The case type of solver entity written out in the .exc solver deck file.
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
EXC_BANDWIDTH
The excitation bandwidth type of solver entity written out in the .exc solver deck file.
Type: string
EXC_VALUE
The solver attribute for excitation value after generation of excitation list written in the .exc solver deck file.
Type: double
EXTYP_NO
The excitation type of solver entity written out in the .exc solver deck file.
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
INPUTLOAD_VALUE
The value of the input load.
Type: double
INPUTOPTION
The input option for excitation load.
101244 - Random
101245 - Periodic
101246 - Transient
internalid
internalname
The internal name of the entity.
Type: string
LINEAR_VAL
The value of the linear frequency bandwidth.
Type: double
LOG_VAL
The value of the logarithmic frequency bandwidth.
Type: double
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
REVERBERANT_VARIABLE
The type of reverberant excitation load.
101251 - Velocity
101253 - Pressure
SCALETYPE
The scale of the excitation load.
101248 - DB
101249 - Linear
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
Version History
2021.2
