loadsteps
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
 - Returns non-zero if the entity is set inactive, 0 otherwise.
 - attributesmax
 - The number of attributes owned by this entity.
 - cardimage
 - The name of the assigned card image.
 - color
 - The 1-64 color of the entity.
 - color_rgb
 - The RGB color of the entity.
 - contactgroups_ids
 - Pointer to the contact groups in the loadstep.
 - contactgroups_idsmax
 - The number of contact groups in the loadstep.
 - curve_ids
 - Pointer to the curves in the loadstep.
 - curve_idsmax
 - The number of curves in the loadstep.
 - definedentity
 - True if the entity is defined, false otherwise.
 - groups_ids
 - Pointer to the groups in the loadstep.
 - groups_idsmax
 - The number of groups in the loadstep.
 - id
 - The ID of the entity.
 - ids
 - Pointer to the loadcols in the loadstep.
 - idsmax
 - The number of loadcols in the loadstep.
 - include
 - The ID of the include file the entity is organized in.
 - includeid
 - internalid
 - internalname
 - The internal name of the entity.
 - loadcollector
 - Pointer to the loadcollector.
 - moduleid
 - The module ID of the entity.
 - name
 - The name of the entity.
 - ob_ids
 - Pointer to the outputblock in the loadstep.
 - ob_idsmax
 - The number of outputblocks in the loadstep.
 - outputsuppressed
 - Returns non-zero if the entity is set "do not export", 0 otherwise.
 - poolid
 - The pool number of the entity.
 - poolname
 - The pool name of the entity.
 - solver_id
 - The solver ID of the entity.
 - solverkeyword
 - The name of the solver keyword.
 - solvername
 - The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Version History
2020 - Added new data names color_rgb. contactgroups_ids and contactgroups_idsmax.
2020.1 - Added new data name solverkeyword.
2021 - Added new data names curve_ids and curve_idsmax.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
