solversettings
Unless otherwise specified, data names are accessible in level 3 only.
Acceleration_Ref
The global Reference value of acceleration written at AREF key. Different from Structural_Output_Acceleration_Ref.
Type: double
Acoustic_Output_Pressure_Ref
The reference value of acoustic output in pressure terms written adjacent to ACOUST key in PAR section in sea file.
Type: double
Acoustic_Output_Type
The type of acoustic output.
100230 - Pressure
Type: unsigned integer
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Beta
The value of the smoothening factor.
Type: double
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
1001 - Seam
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
Displacement_Ref
The global reference value of displacement written at DREF key. Different from Structural_Output_Displacement_Ref.
Type: double
Energy_Ref
The reference value of the energy in energy output written at EREF key.
Type: double
Force_Ref
The reference value of the force written at FREF key.
Type: double
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
Intensity_Ref
The reference value of the intensity in energy output written at IREF key.
Type: double
internalid
internalname
The internal name of the entity.
Type: string
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
Power_Ref
The reference value of the power in power output written at PREF key.
Type: double
Pressure_Ref
The global reference value of pressure written at PRREF key. Different from Acoustic_Output_Pressure_Ref.
Type: double
SEAM_MODEL_UNITS
The model units for seam entities and their data written at UNITS key in sea file.
100261 - mks
100262 - cgs
100263 - mm-kg-sec
100264 - fps
100265 - ips
100266 - ft-lb-sec
100267 - in-lb-sec
SEAM_REF_UNITS
The reference units for seam entities and their data written at REFUNITS key in sea file. The reference values in sea file are in this system.
100261 - mks
100262 - cgs
100263 - mm-kg-sec
100264 - fps
100265 - ips
100266 - ft-lb-sec
100267 - in-lb-sec
Solution_Type
The type of solution.
100237 - Transient
100238 - Steady State
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
The reference value of the structural output in acceleration terms written adjacent to STRUCT key in PAR section in sea file.
Type: double
The reference value of the structural output in displacement terms written adjacent to TRUCT key in PAR section in sea file.
Type: double
Structural_Output_Type
The type of structural output.
100223 - Displacement
100224 - Velocity
100225 - Acceleration
Structural_Output_Velocity_Ref
The reference value of the structural output in velocity terms written adjacent to STRUCT key in PAR section in sea file.
Type: double
Variance_Options
The type of variance option.
100233 - None
100234 - Analysis Bandwidth
100235 - Narrowband
Velocity_Ref
The global reference value of velocity written at VREF key. Different from Structural_Output_Velocity_Ref.
Type: double
Version History
2021.2
