frequencysets
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
Analysis_Frequency_Bandwidth
The types of analysis bandwidth.
100201 - One_Third_Octave
100202 - Octave
100203 - Log
100204 - Linear
Type: unsigned integer
Analysis_Frequency_Bandwidth_Linear_Value
The frequency value of analysis bandwidth in linear scale (decades).
Type: double
Analysis_Frequency_Bandwidth_Log_Value
The frequency value of analysis bandwidth in log scale (Hz).
Type: double
attributesmax
The number of attributes owned by this entity.
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
1001 - Seam
Counting_Frequency_Bandwidth
The types of counting bandwidth.
100202 - Octave
100203 - Log
100204 - Linear
Counting_Frequency_Bandwidth_Linear_Value
The frequency value of counting bandwidth in linear scale (decades).
Type: double
Counting_Frequency_Bandwidth_Log_Value
The frequency value of counting bandwidth in log scale (Hz).
Type: double
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
Frequency_Higher_Range
The higher range of frequency definition for octave and one-third octave bands in analysis bandwidth and counting bandwidth. Not applicable for log and linear scales.
Type: double
Frequency_Lower_Range
Type: double
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
internalname
The internal name of the entity.
Type: string
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
Version History
2021.2
