alereferencesystemnodes
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
101 - LS-DYNA *ALE_REFERENCE_SYSTEM_NODE
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
internalname
The internal name of the entity.
Type: string
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
nid1
The first node ID.
Type: entity
nid2
The second node ID.
Type: entity
nid3
The third node ID.
Type: entity
nid4
The fourth node ID.
Type: entity
nid5
The fifth node ID.
Type: entity
nid6
The sixth node ID.
Type: entity
nid7
The seventh node ID.
Type: entity
nid8
The eighth node ID.
Type: entity
nid9
The ninth node ID.
Type: entity
nid10
The tenth node ID.
Type: entity
nid11
The eleventh node ID.
Type: entity
nid12
The twelfth node ID.
Type: entity
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
Version History
2019
2020 - Added new data name color_rgb.
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
