properties
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
 - Returns non-zero if the entity is set inactive, 0 otherwise.
 - attributesmax
 - The number of attributes owned by this entity.
 - cardimage
 - The name of the assigned card image.
 - cardimagetype
 - The type of the assigned card image.
 - color
 - The 1-64 color of the entity.
 - color_rgb
 - The RGB color of the entity.
 - definedentity
 - True if the entity is defined, false otherwise.
 - encrypted
 - True if the entity is encrypted, false otherwise.
 - id
 - The ID of the entity.
 - include
 - The ID of the include file the entity is organized in.
 - includeid
 - internalid
 - internalname
 - The internal name of the entity.
 - laminate
 - The ID of the laminate linked to the property (for example, /PROP/STACK or /PROP/TYPE51). This data name is not used for other properties in Radioss, nor at all in other profiles.
 - material
 - A pointer to the material assigned to the property. This will always be a valid material ID if one is assigned.
 - materialid
 - The ID of the material assigned to the property. This could be a valid material ID or unresolved material ID.
 - moduleid
 - The module ID of the entity.
 - name
 - The name of the entity.
 - outputsuppressed
 - Returns non-zero if the entity is set "do not export", 0 otherwise.
 - poolid
 - The pool number of the entity.
 - poolname
 - The pool name of the entity.
 - section
 - The ID of the section entity assigned to the property.
 - sensor
 - The ID of the sensor entity assigned to the property.
 - solver_id
 - The solver ID of the entity.
 - solverkeyword
 - The name of the solver keyword.
 - solvername
 - The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
 - thickness
 - The thickness of the property. This is only available for "core" solver templates routinely maintained by Altair.
Version History
2017.2 - Added new data name laminate.
2019 - Added new data name thickness.
2020 - Added new data name color_rgb.
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
2022 - Added new data names section and sensor.
