retractors
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
101 - LS-DYNA *ELEMENT_SEATBELT_RETRACTOR
401 - PAM-CRASH RETRA
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
entityselection
The ID of the bar element selection for inside belt webbing.
Type: entity
fedlength
The fed length.
Type: double
filmspoolcurveid
The ID of the film spool effect curve after locking.
Type: entity
flagtodisableelements
The flag to disable elements definition.
forcevalue
The retractor pretension force value.
Type: double
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
internalname
The internal name of the entity.
Type: string
lengthfractionpullin
The length fraction for retractor element pull-in.
Type: double
lengthfractionpullout
The length fraction for retractor element pull-out.
Type: double
loadingcurveid
The ID of the loading curve.
Type: entity
loadlimitcurveid
The ID of the load limit curve for the load limiter stage.
Type: entity
loadlimiter
The number of load limiter stages.
loadlimitflag
The flag for reference length selection.
loadingsensorid
The ID of the sensor triggering the load limiter stage.
Type: entity
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
pretensionercurveid
The ID of the characteristic force limit curve for the pyrotechnical pretensioner.
Type: entity
pull
The amount of pull-out between time delay ending and retractor locking, a length value.
Type: double
retractorcpoint
The ID of the seatbelt control point.
Type: entity
retractornodeid
The ID of the retractor node or node set.
Type: entity
retractorparent
The ID of the parent seatbelt.
Type: entity
seatbeltelemid
The ID of the seatbelt element or element set, depending on retractornodeid.
Type: entity
sensorid1
The ID of sensor 1 of type *ELEMENT_SEATBELT_SENSOR.
Type: entity
sensorid2
The ID of sensor 2 of type *ELEMENT_SEATBELT_SENSOR.
Type: entity
sensorid3
The ID of sensor 3 of type *ELEMENT_SEATBELT_SENSOR.
Type: entity
sensorid4
The ID of sensor 4 of type *ELEMENT_SEATBELT_SENSOR.
Type: entity
signedsensors1
A positive or negative signed value.
Type: string
signedsensors2
Type: string
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
timedelay
The time delay after the sensor triggers.
Type: double
type
The type of retractor. Available types are node (1) or set (10).
unloadingcurveid
The ID of the unloading curve.
Type: entity
Version History
2017.1
2020 - Added new config value 401. Added new data names color_rgb, entityselection, filmspoolcurveid, flagtodisableelements, forcevalue, lengthfractionpullin, lengthfractionpullout, loadlimitcurveid, loadlimiter, loadlimitflag, loadsensorid, pretensionercurveid, retractorcpoint, retractorparent, signedsensors1 and signedsensors2.
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
