attachmentcontrols
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
1 - Rigid spider
2 - Rigid patch
connectouterlayer
The way to connect to the hole for config 1.
Type: string
createelements
True if an element set is created, false if a node set is created.
Type: Boolean
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
duplicateelems
True if a projection element is duplicated, false if the original projection element is used.
Type: Boolean
elemtype
The element type name for config 1.
Type: string
engname
The engineering name.
Type: string
feature
The attachment feature for config 2. Valid values are Hole and Projection.
Type: string
holeandwasher
The option to fill hole or use washer elements for config 2.
Type: string
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
internalname
The internal name of the entity.
Type: string
maxdia
The maximum diameter for finding a hole when findhole is 1.
Type: double
maxlayers
The number of layers to create projection attachment for config 2.
mindia
The minimum diameter for finding a hole when findhole is 1.
Type: double
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
Version History
2020
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names createelements, duplicateelems, feature, and maxlayers. Removed data name findhole.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
