physicalquantities
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
conductivity
The thermal conductivity.
Type: double
config
The configuration of the entity.
601 - ADVC $FilmCoefficient
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
filmcoeff_depend
Specifies the thermal conductivity dependent defined in filmcoeff_table.
0 - Temperature
1 – Surface Temperature
2 – Contact Surface Gap
3 – Contact Pressure
Type: integer
filmcoeff_table
The ID of the curve defining the reference temperature versus thermal conductivity when filmcoeff_depend is 0, element surface temperature versus thermal conductivity when filmcoeff_depend is 1, contact surface gap versus thermal conductivity when filmcoeff_depend is 2, and the contact pressure versus thermal conductivity when filmcoeff_depend is 3.
Type: entity
filmcoeff_type
Specifies how the thermal conductivity in the film coefficient is defined.
0 - Constant
1 - Table
Type: integer
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
internalname
The internal name of the entity.
Type: string
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
position
Reference position (dimensionless).
Type: double
sink_temperature
Defined as an external temperature when the thermal conductivity is referred to in the heat convection boundary condition or defined as the lower surface temperature when the thermal conductivity is referred to in the heat convection boundary condition specified in the heat convection elements.
Type: double
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
table_style
Specifies the table style defined in filmcoeff_table as:
Temperature
ContactGap
ContactPressure
Type: string
Version History
2021
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names filmcoeff_depend, filmcoeff_table, filmcoeff_type, internalname, position, sink_temperature, solvername, and table_style.
