parameters
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
 - Returns non-zero if the entity is set inactive, 0 otherwise.
 - attributesmax
 - The number of attributes owned by this entity.
 - caddimension
 - The parameter CAD dimensionality:
 - cadfullname
 - The full name of the parameter in the CAD system.
 - cadsystem
 - The originating CAD system:
 - cadunits
 - The CAD system units associated to the parameter:
 - cardimage
 - The name of the assigned card image.
 - cardimagetype
 - The type of the assigned card image.
 - config
 - The configuration of the entity.
 - definedentity
 - True if the entity is defined, false otherwise.
 - discrete_dv
 - The list of discrete values. This is valid when usage is 5.
 - discrete_dv_count
 - The number of discrete values. This is valid when usage is 5.
 - dvlink
 - The design variable linking one parameter to another.
 - dvmode
 - The design variable type. Valid values are Continuous, Discrete, Categorical.
 - formulalist
 - The list of entities parameterized in a formula list. Returns [entity_type addition_type clause_type entity_ids].
 - id
 - The ID of the entity.
 - include
 - The ID of the include file the entity is organized in.
 - includeid
 - internalid
 - internalname
 - The internal name of the entity.
 - isactive
 - Indicates whether dvlink is active or not.
 - localname
 - The visible name visible for local parameters. This name may be duplicated for local parameter across different includes. Valid only for LS-DYNA.
 - moduleid
 - The module ID of the entity.
 - name
 - The name of the entity.
 - outputsuppressed
 - Returns non-zero if the entity is set "do not export", 0 otherwise.
 - parameter_opti_allowables_double
 - The values equal to the number defined. This is applicable when usage is 3 and type is 0.
 - parameter_opti_allowables_double_count
 - The number of allowable double values. This is applicable when usage is 3 and type is 0.
 - parameter_opti_allowables_int
 - The values equal to the number defined. This is applicable when usage is 3 and type is 1.
 - parameter_opti_allowables_int_count
 - The number of allowable integer values. This is applicable when usage is 3 and type is 1.
 - poolid
 - The pool number of the entity.
 - poolname
 - The pool name of the entity.
 - qualifierlist
 - The list of attributes/datanames parameterized. Returns [entity_type attribute_number row_index column_index].
 - range_double_lower
 - The lower range of double value. This is applicable when when usage is 4 and type is 0.
 - range_double_upper
 - The upper range of double value. This is applicable when when usage is 4 and type is 0.
 - range_int_levels
 - The integer value for the of levels between the lower and upper range. This is applicable when when usage is 4 and type is 0 or 1.
 - range_int_lower
 - The lower range of integer value. This is applicable when when usage is 4 and type is 1.
 - range_int_upper
 - The upper range of integer value. This is applicable when when usage is 4 and type is 1.
 - solver_id
 - The solver ID of the entity.
 - solverkeyword
 - The name of the solver keyword.
 - solvername
 - The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
 - symbol_quantity
 - The quantity of a parameter when the usage value is 6.
 - type
 - The solver dependent type code for the entity.
 - usage
 - The usage of the entity.
- 0 - General
 - 2 - CAD
 - 3 - Discrete
 - 4 - Continuous
 - 5 - Design variable
 - 6 - Symbol
 - usesexpression
 - True if expression is used, otherwise false. Valid for hm_getvalue query only.
 - valueexpression
 - The value of a parameter when when type is 3 or 4.
 - valuedouble
 - The value of a parameter when type is 0.
 - valueint
 - The value of a parameter when type is 1.
 - valuestring
 - The value of a parameter when type is 2.
 - varmgrinclude
 - The flag to enable/disable the parameter entity in the variable manager.
 - varname
 - The variable name when usage is 5.
Version History
2019 - Added new data name localname.
2019.1 - Added new config value 6 and usage value 5. Added new data names dvlink, isactive and varname.
2020 - Added new data names discrete_dv, discrete_dv_count and dvmode.
2021 - Added new data names caddimension, cadfullname, cadsystem and cadunits. Added new config 2.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added the new data names internalname, solvername, symbol_quantity, and varmgrinclude. Added new config value 7 and new usage value 6.
