modelcheckcorrections
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
cardedit
The card edit to be opened.
Type: string
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
1 - Automatic
2 - Manual
correctvalue
The user input value to run the correction.
Type: string
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
entityeditor
The entity editor to be opened.
Type: string
filename
The file in which the auto-correction is present.
Type: string
functionname
The function to execute to perform the auto-correction.
Type: string
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
option
The manual correction option.
Type: integer
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
panel
The panel to be opened.
Type: string
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
tclfile
The Tcl file in which the Tcl auto-correction is present.
Type: string
tclgui
The Tcl GUI to be opened.
Type: string
Version History
2019
2020 - Added new data name color_rgb.
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
