timestepcontrols
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
analysis_type
The time step analysis type:
0 - Structural (default)
1 - Heat transfer
Type: unsigned integer
attributesmax
The number of attributes owned by this entity.
auto_increment
The automatic or fixed time step function:
yes - Automatic
no - Fixed
Type: string
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
601 - ADVC $TimeStep
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
internalname
The internal name of the entity.
Type: string
list_output_interval
The output interval of the thermostat history output (step).
Type: integer
load_type
The time history of the load condition specified with a constant:
Ramp
Step
Type: string
load_type_for_coupling_analysis
The time history of the load condition for coupling analysis specified with a constant:
Ramp
Step
Type: string
max_change
An indication of the upper limit of the temperature change within one time step.
Type: double
max_dt
The upper limit of the time step width.
Type: double
max_time
The analysis time.
Type: double
min_dt
The lower limit of the time step width.
Type: double
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
number_of_iterations
The number of iterations of the time step width in an array.
Type: integer array
number_of_time_step_width
The number of time step width data in a table.
output_init
The result output at the start of the process:
yes - Output
no - Do not output
Type: string
output_interval
The output interval of the analysis results within the process (step).
Type: integer
output_last
The result output at the end of the process:
yes - Output
no - Do not output
Type: string
output_time_interval
The output interval of the analysis results within the process (time).
Type: double
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
process_id
The loadstep ID for which the time step is defined.
Type: entity
resout_interval
The output interval of the restart file within the process (step).
resout_last
The restart file output at the end of the process:
yes - Output
no - Do not output
Type: string
resout_time_interval
The output interval of the restart file within the process (time).
Type: double
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
steady_rate
The steady state termination condition.
Type: double
time_step_width
The time step width array.
Type: double array
Version History
2021
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
