seamsubsystems
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
config
The configuration of the entity.
1001 - Structural
1002 - Acoustic
color_rgb
The RGB color of the entity.
Type: string
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
internalname
The internal name of the entity.
Type: string
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
SUBS_ID
The ID of the SEAMSubsytem solver entity.
SUBS_ELEM_ID
The element ID of the SEAMSubsytem solver entity.
SUBS_ELEM_TYPE
The element type of the SEAMSubsytem solver entity.
SUBS_FL_CLONG
The speed of sound in the fluid.
Type: double
SUBS_FL_DENSITY
The fluid material density.
Type: double
SUBS_FL_MAT
The fluid material of the SEAMSubsytem solver entity.
Type: entity
SUBS_FL_THICKNESS
The thickness of the fluid material.
Type: double
SUBS_MATDATA1
The material data 1 of the SEAMSubsytem solver entity.
Type: double
SUBS_MATDATA2
The material data 2 of the SEAMSubsytem solver entity.
Type: double
SUBS_MATDATA3
The material data 3 of the SEAMSubsytem solver entity.
Type: double
SUBS_MATDATA4
The material data 4 of the SEAMSubsytem solver entity.
Type: double
SUBS_MATDATA5
The material data 5 of the SEAMSubsytem solver entity.
Type: double
SUBS_MATDATA6
The material data 6 of the SEAMSubsytem solver entity.
Type: double
SUBS_MATTYPE
The material type of the SEAMSubsytem solver entity.
Type: string
SUBS_OPTION
The options for the SEAMSubsytem solver entity.
Type: string
SUBS_SECTIONSIZE
The section size of the SEAMSubsytem solver entity.
Type: double
SUBS_SHAPESIZE
The shape size of the SEAMSubsytem solver entity.
Type: double
SUBS_TYPE
The type of the SEAMSubsytem solver entity.
Version History
2021.2
