integrationrules
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
101 – INTEGRATION_BEAM
102 – INTEGRATION_SHELL
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
D1
The cross-section dimension D1.
Type: double
D2
The cross-section dimension D2.
Type: double
D3
The cross-section dimension D3.
Type: double
D4
The cross-section dimension D4.
Type: double
D%
The cross-section dimension D5.
Type: double
D6
The cross-section dimension D6.
Type: double
ESOP
Equal spacing of integration points option.
0 - Integration points are defined below
1 - Integration points are equally spaced through thickness
Type: integer
FAILOPT
Treatment of failure when mixing different constitutive types, which do and do not include failure models, through the shell thickness.
0 - Element is deleted when the layers which include failure, fail
1 - Element failure cannot occur since some layers do not have a failure option
Type: integer
ICST
The type of standard cross section.
0 - Default
1 - I-Shape
2 – Channel
3 - L-Shape
4 - T-shape
5 - Tubular box
6 - Z-Shape
7 – Trapezoidal
8 – Circular
9 – Tubular
10 - I-Shape 2
11 – Solid Box
12 – Cross
13 - H-Shape
14 - T-Shape 2
15 - I-Shape 3
16 - Channel 2
17 - Channel 3
18 - T-Shape 3
19 - Box-Shape 2
20 – Hexagon
21 - Hat-Shape
22 - Hat-Shape 2
Type: integer
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
internalname
The internal name of the entity.
Type: string
K
The integration refinement parameter.
Type: integer
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
NIP
The number of integration points.
Type: integer
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
PID
The ID of the component (*PART) entity.
Type: entity array
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
RA
The relative area of the cross section.
Type: double
S
The normalized S-coordinate of the integration point.
Type: double array
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
SREF
Location of reference surface normal to S.
Type: double
T
Normalized T-coordinate of integration point.
Type: double array
TREF
Location of reference surface normal to T.
Type: double array
WF
The weighting factor.
Type: double array
Version History
2022
