mechanismconstraints
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
body1
The body to be constrained.
Type: entity
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
15 - Point location
16 - Point node
17 - Coupler/linker
18 - Distance
couplerid
The ID of the linker constraint.
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
distance
The disatance to be maintained between two nodes for config 18.
Type: double
distance_node_1
The node 1 ID for config 18. The specified distance is maintained between distance_node_1 and distance_node_2.
Type: entity
distance_node_2
The node 2 ID for config 18. The specified distance is maintained between distance_node_1 and distance_node_2.
Type: entity
factor1
The ratio of movement between linked joints.
factor1 * movement of joint1 + factor2 * movement of joint2 = 0
Type: double
factor2
Type: double
factor3
The ratio of movement between linked joints when three joints are linked.
factor1 * movement of joint1 + factor2 * movement of joint2 + factor3 * movement of joint3 = 0
Type: double
fixed_dof
The degrees of freedom of the entity.
Type: integer array
fixed_dof_system
The local coordinate system used to define fixed_dof.
Type: entity
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
internalname
The internal name of the entity.
Type: string
joint1
The ID of joint 1 for linked joints.
Type: entity
joint1_axis
The degree of freedom of the first linked joint. 0/1/2 are translation degrees of freedom in the x/y/z axis of the joint respectively. 3/4/5 are rotational degrees of freedom around the x/y/z axis of the joint respectively.
joint2
The ID of joint 2 for linked joints.
Type: entity
joint2_axis
The degree of freedom of the second linked joint. 0/1/2 are translation degrees of freedom in the x/y/z axis of the joint respectively. 3/4/5 are rotational degrees of freedom around the x/y/z axis of the joint respectively.
joint3
The ID of joint 3 for linked joints.
Type: entity
joint3_axis
The degree of freedom of the third linked joint. 0/1/2 are translation degrees of freedom in the x/y/z axis of the joint respectively. 3/4/5 are rotational degrees of freedom around the x/y/z axis of the joint respectively.
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
pointnode
The node at which the constraint is defined.
Type: entity
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
position1
The coordinate location of the constraint.
Type: triple double
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
Version History
2020 - Added new data names color_rgb, couplerid, color_rgb, distance, distance_node_1, distance_node_2, factor1, factor2, factor3, joint1, joint1_axis, joint2, joint2_axis, joint3 and joint3_axis. Added new config values 17 and 18.
2020.1 - Added new data name solverkeyword.
2021.1 – Added new data names for LS-DYNAengineering loads: activation_time, ang_vel_center, curveid, deactivation_time, displayname, dof1, dof2, dof3, dof4, dof5, dof6, inputsystem, keyword_name, load_boundary_nodes, load_dof, magnitude, motion_rigid_local_option, motion_type, motion_vec_dir, nodal_rigid_body, plane_axis_coord1, plane_axis_coord2, plane_node2, plane_node3, rel_disp_ref_body, rigid_part, rigidbody_option, sort_nodes, symmetry_repetition_dir, and time_activate_option,moduleid, poolid,poolname, solver_id.
2021.2 - Added new data names internalname and solvername.
