seamjunctions
Unless otherwise specified, data names are accessible in level 3 only.
A_DimType
The dimension type of Acoustic connection.
Type: unsigned integer
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
ACOUSTIC_BOTTOM
The bottom acoustic seasubsystem associated with structural-acoustic connection.
Type: entity
ACOUSTIC_ELEM1
The top acoustic seasubsystem associated with acoustic connection.
Type: entity
ACOUSTIC_ELEM2
The bottom acoustic seasubsystem associated with acoustic connection.
Type: entity
ACOUSTIC_TOP
The top acoustic seasubsystem associated with structural-acoustic connection.
Type: entity
Area
The area of structural acoustic connection.
Type: double
Area_Val
The area of acoustic connection.
Type: double
attributesmax
The number of attributes owned by this entity.
BARRIER
The barrier seasubsystem associated with structural-acoustic connection.
Type: entity
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
1001 - Structural
1002 - Structural Acoustic
1003 - Acoustic
1004 - Solver
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
DimType
The dimension type of the structural connection.
101201 - Line
101202 - Arc
101203 - Point
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
internalname
The internal name of the entity.
Type: string
JUNC_LINES
The graphics (lines) attached to seamjunctions.
Type: entity
JUNC_POINTS
The graphics (points) attached to seamjunctions.
Type: entity
JUNC_SURFACES
The graphics (surfaces) attached to seamjunctions.
Type: entity
Length
The length of the structural connection for line and arc dimension types.
Type: double
LRad
The radiation length of the structural acoustic connection.
Type: double
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
Number
The number of points in the point dimension type of the structural connection.
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
S_TemplateType
The template type of structural connection.
101207 - Parallel
101208 - Beams
101209 - Beam-Plate
101210 - X-Cross
101211 - Frame
SA_TemplateType
The template type of structural acoustic connection.
102201 - Single Wall
102202 - Loaded Panel
102203 - Beam Radiation
102204 - Trimmed Panel
SEAMJUNCTION_CON_ID
The ID of the element.
SEAMJUNCTION_ID
The ID of the SEAM junction solver entity.
SEAMJUNCTION_TYPE
The type of SEAM junction solver entity.
Type: string
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
STRUCTURE
The structural seasubsystem associated with structural-acoustic connection.
Type: entity
STRUCTURE_A
Type: entity
STRUCTURE_B
Type: entity
STRUCTURE_C
Type: entity
STRUCTURE_D
Type: entity
STRUCTURE_E
Type: entity
STRUCTURE_F
Type: entity
STRUCTURE_G
Type: entity
STRUCTURE_H
Type: entity
STRUCTURE_I
Type: entity
TRIMLAYER
The trimlayer seasubsystem associated with structural-acoustic connection.
Type: entity
Width
The width of the structural acoustic connection.
Type: double
Version History
2021.2
2022 –Added new data names acoustic_bottom, acoustic_elem1, acoustic_elem2, acoustic_top, barrier, junc_lines, junc_points, junc_surfaces, structure, structure_a, structure_b, structure_c, structure_d, structure_e, structure_f, structure_g, structure_h, structure_i, and trimlayer.
