multibodies
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
cardimage
The name of the assigned card image.
Type: string
cardimagetype
The type of the assigned card image.
Type: string
center
The global coordinates of the center of gravity. Valid for hm_getvalue query only.
Type: triple double
centerx
The x coordinate of the element centroid.
Type: double
centery
The y coordinate of the element centroid.
Type: double
centerz
The z coordinate of the element centroid.
Type: double
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
globalx
The global x coordinate of the center of gravity.
Type: double
globaly
The global y coordinate of the center of gravity.
Type: double
globalz
The global z coordinate of the center of gravity.
Type: double
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
localcenter
The local coordinates of the center of gravity. Valid for hm_getvalue query only.
Type: triple double
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
system
A pointer to the the local coordinate system of the multibody.
Type: pointer
systemid
The ID of the local coordinate system of the multibody.
Type: integer
Version History
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
