objectives
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
configname
The solver name of the entity. Valid for hm_getvalue query only.
Type: string
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
dobjreflist
The list of dobjrefs that refer to the objective. Valid for hm_getvalue query only.
Type: entity array
dobjreflistmax
The number of dobjrefs that refer to the objective. Valid for hm_getvalue query only.
Type: integer
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
internalname
The internal name of the entity.
Type: string
loadstepid
The ID of the assigned loadstep.
Type: integer
minmaxflag
Objective type flag. Valid values are:
  • 0 - minimize
  • 1 - maximize
  • 2 - minmax
  • 3 - maxmin
Type: integer
minmaxflagname
Objective type flag name. Valid for hm_getvalue query only.
Type: string
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
responseid
The ID of the assigned response.
Type: integer
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
Version History
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
