equations
Unless otherwise specified, data names are accessible in level 3 only.
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
collector
Pointer to the collector that owns the equation.
Type: pointer (levels 2, 3 and 4)
constant
The constant for the equation.
Type: double (levels 2, 3 and 4)
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
dependentcoeff
The dependent coefficient of the equation.
Type: double
dependentdof
The dependent degree of freedom.
Type: integer
dependentnode
Pointer to the dependent node.
Type: pointer
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
independentcoeffs
Pointer to the independent coefficients (use with pointerset - pointerset(pointer3,independentcoeffs,0)).
independentdofs
Pointer to the independent degrees of freedom (use with pointerset - pointerset(pointer2,independentdofs,0)).
independentnodes
Pointer to the independent nodes (use with pointerset - pointerset(pointer1,independentnodes,0)).
independentnodesmax
The number of independent nodes.
Type: integer
internalid
internalname
The internal name of the entity.
Type: string
lsdindependentcoeffs
The coefficients of nodes belonging to independent nodes in LS-DYNA profile.
Type: string array
moduleid
The module ID of the entity.
Type: integer
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
type
The solver dependent type code for the entity.
Type: integer
typename
The solver dependent type name for the entity.
Type: string
Version History
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
2022 – Added new data names lsdindependentcoeffs.
