weldlines
Unless otherwise specified, data names are accessible in level 3 only.
- active_weld_type
 - The type of active weld.
 - activesuppressed
 - Returns non-zero if the entity is set inactive, 0 otherwise.
 - attributesmax
 - The number of attributes owned by this entity.
 - config
 - The configuration of the entity.
 - definedentity
 - True if the entity is defined, false otherwise.
 - Eval_select
 - True selected for analysis, false not selected for analysis.
 - Evaluation_distance_table
 - The table entity ID containing the evaluation distance calculation details.
 - General_table
 - The table ID consisting of the general location details.
 - HAZ_set
 - The EL2MAT set of the heat-affected zone element sets.
 - HAZ_size
 - The heat affected zone size.
 - id
 - The ID of the entity.
 - include
 - The ID of the include file the entity is organized in.
 - includeid
 - internalid
 - internalname
 - The internal name of the entity.
 - Location_table
 - The table ID consisting of the location details for each location point.
 - moduleid
 - The module ID of the entity.
 - name
 - The name of the entity.
 - outputsuppressed
 - Returns non-zero if the entity is set "do not export", 0 otherwise.
 - poolid
 - The pool number of the entity.
 - poolname
 - The pool name of the entity.
 - Result_status
 - True if damage is ≤ 0, false if damage > 0.
 - Resultvalue
 - The damage value.
 - solver_id
 - The solver ID of the entity.
 - solverkeyword
 - The name of the solver keyword.
 - solvername
 - The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
 - Weld_bevel_angle
 - The weld bevel angle (α).
 - Weld_detection
 - Indicates whether the weld is shell or solid.
 - Weld_part
 - The component ID of the 1D elements to set.
 - Weld_perform_class
 - The weld performance class. Valid values are CP A, CP B, CP C1, CP C2, and CP D.
 - Weld_root_face
 - The weld root face (c).
 - Weld_root_opening
 - The weld root opening (b).
 - Weld_sub_type
 - The weld sub-type.
 - Weld_thickness
 - The weld thickness (a).
 - Weld_type
 - The type of weld. Valid values are Butt, Cross, L, Multiple, Overlap and T.
 - weldlocationentityids
 - The table ID consisting of the location entity IDs for each point location.
Version History
2020
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names active_weld_type, moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names Evaluation_distance_table, HAZ_size, HAZ_set, internalname,solvername, Weld_bevel_angle, Weld_perform_class, Weld_root_face, Weld_root_opening, Weld_sub_type, and Weld_thickness.
