features
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
associativity
Returns true if geometry and FE entities are associated.
Type: Boolean
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
3 - Dimension
4 - Holes2D
5 - Holes3D
6 - Fillets
7 - Flanges2D
8 - Flanges3D
9 - Chamfers
10 - Stiffeners
11 - Bosses
12 - Logos
Type: unsigned integer
config_color
The 1-64 color of each config entity.
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
dim_lockside
The end point lock control that determines the dimension modification side (integer). Valid values are:
0 - None
1 - Point1
2 - Point2
3 - Both
Type: integer
dim_sides_selection
Option for selecting the involved surfaces in dimension modification.
0 - Auto
1 - Manual
Type: integer
elem_ids
The list of element IDs inside a feature. Valid for FE features.
Type: entity array
feature_height
The height of the 3D hole for config 5, the height of the logo for config 12.
Type: double
feature_length
The length of the feature. Valid for config 6 and 7.
Type: double
feature_minwidth
The minimum width of a feature. Valid for config 6 and 7.
Type: double
feature_maxwidth
The maximum width of a feature. Valid for config 6 and 7.
Type: double
feature_type
The type of the feature.
0 - Geometric feature.
1 - Any other feature.
feature_shape
The shape of the feature.
For 2D and 3D holes:
1 - General.
2 - Circular.
4 - Rounded.
8 - Rectangular.
16 - Square.
For fillets:
9 - Fillet.
10 - Round.
fillet_maxangle
The maximum angle of a fillet.
Type: double
fillet_maxradius
The maximum radius of a fillet.
Type: double
fillet_minangle
The minimum angle of a fillet.
Type: double
fillet_minradius
The minimum radius of a fillet.
Type: double
fillet_ratio
The ratio between the minimum and maximum radius.
Type: double
hm_dimension_length
The distance between point1 and point2 for dimension features.
Type: double
hole_axis
The normal Axis of a 2D hole feature. Valid for config 4.
Type: triple
hole_center
The center of a 2D hole feature. Valid for config 4.
Type: triple
hole_ratio
The ratio between hole_size1 and hole_size2 of a 2D hole feature. Valid for config 4.
Type: double
hole_size1
The first size parameter of a 2D hole feature. Returns radius for feature_shape 2, side length for feature_shape 16, the length for feature_shape 8, the tip radius for feature_shape 4 and the average radius for feature_shape 1. Valid for config 4.
Type: double
hole_size2
The second size parameter of a 2D hole feature. Returns none for feature_shape 2, none for feature_shape 16, the width for feature_shape 8, the distance between tip centers for feature_shape 4 and none for feature_shape 1. Valid for config 4.
Type: double
id
The ID of the entity.
ids
The IDs of the entities inside a feature.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
internalname
The internal name of the entity.
Type: string
invalid
Returns true if feature is invalid and needs to be updated, else false.
Type: Boolean
line_ids
The list of line IDs inside the feature. Valid for config 4 and feature_type 0.
Type: entity array
logo_concavityfactor
The concavity factor of logos.
Type: double
logo_size
Type: double
logo_string
The logo string.
Type: string
max_expand_angle
The angle that measures along the edge over which they are adjacent to the selected surface, and controls the appending of the surfaces to the already selected surfaces.
Type: double
max_pick_tilt
The angle that measures between the normal to the surface at the dimension end and the dimension direction, and controls the automatic selection of involved surfaces.
Type: double
minimum_slide_angle
The angle that controls whether the involved surfaces in dimension modification will slide/drag.
Type: double
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
node_ids
The list of node IDs inside the feature. Valid for FE feature config 4.
origin
The originating source of the feature.
For dimension features, this is always HyperMesh.
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
point1
The ID of the first vertex point for dimension features.
Type: entity
point2
The ID of the second vertex point for dimension features.
Type: entity
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
region_2delems
The region entity inside a feature holding all 2D elements.
Type: entity
region_2dedges
The region entity inside a feature holding all edges. Valid for FE feature config 4.
Type: entity
region_3delems
The region entity inside feature holding all 3D elements.
Type: entity
region_lines
The region entity inside feature holding all lines. Valid for feature_type 0 and config 4.
Type: entity
region_surfs
The region entity inside feature holding all surfaces.
Type: entity
remove_collapsed_surfaces
0 - Do not remove collapsed surfaces during dimension feature modification
1 - Remove collapsed surfaces during dimension feature modification
separator_lines
The list of lines for which new surfaces will be generated to keep the surface continuous during dimension modification.
Type: entity array
side_selection_ratio
The ratio that controls the involved surfaces automatic selection by calculating the area of the surfaces on both sides and modifying the end points lock controls.
Type: double
solidhole_axis
The Axis of a 3D hole feature. Valid for config 5.
Type: triple
solidhole_blind
Returns 1 if solid hole is covered on either side. Valid for config 5.
Type: Boolean
solidhole_bottomradmax
The bottom rim maximum radius. Valid for config 5.
Type: double
solidhole_bottomradmin
The bottom rim minimum radius. Valid for config 5.
Type: double
solidhole_bottomrims
The entities making the bottom rim of a 3D hole. Returns line IDs for geometry features and node IDs for FE features. Valid for config 5.
Type: entity array
solidhole_center
Center of a 3D hole feature. Valid for config 5.
Type: triple
solidhole_topradmax
The top rim maximum radius. Valid for config 5.
Type: double
solidhole_topradmin
The top rim minimum radius. Valid for config 5.
Type: double
solidhole_toprims
The entities making the top rim of the 3D hole. Returns line IDs for geometry features and node IDs for FE features. Valid for config 5.
Type: entity array
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
surf_ids
The list of surface IDs inside the feature. Valid for feature_type 0.
Type: entity array
surfaces_interpolation_system
The involved surfaces interpolation system to use during dimension modification.
0 - Automatic (automatically decides between local/global interpolation system)
1 - Local (local coordinate system-based 2D interpolation)
2 - Global (global coordinate system-based 1D linear interpolation)
Type: integer
surfaces_to_move
The list of surfaces manually selected for dimension modification.
Type: entity array
Version History
2020 - Added new data name color_rgb.
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.1 - Added new options associativity,config_color, dim_sides_selection, elem_ids, feature_height, feature_length, feature_minwidth, feature_maxwidth, feature_type, feature_shape, fillet_maxangle, fillet_maxradius, fillet_minangle, fillet_minradius, fillet_ratio, hole_axis, hole_center, hole_ratio, hole_size1, hole_size2, ids, invalid, line_ids, logo_concavityfactor, logo_size, logo_string, node_ids, region_2delems, region_2dedges, region_3delems, region_lines, region_surfs, solidhole_axis, solidhole_blind, solidhole_bottomradmax, solidhole_bottomradmin, solidhole_bottomrims, solidhole_center, solidhole_topradmax, solidhole_topradmin, solidhole_toprims, and surf_ids.
2021.2 - Added new data names internalname and solvername.
