resultsimulations
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
internalname
The internal name of the entity.
Type: string
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
rdataid
The solver ID of the simulation. This ID could be different from the HyperMesh resultsimulation entity ID. Valid for hm_getvalue query only.
Type: integer
solver_id
The solver ID of the entity.
Type: integer
solver_label
The label for the simulation as written in the result file. This label is different from the HyperMesh label for result simulation entity. Valid for hm_getvalue query only.
Type: string
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
subcaseid
The parent subcase ID. Valid for hm_getvalue query only.
Type: integer
Version History
2021.2
