referencegeometries
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
bagid
The ID of the airbag. Valid for config 104.
Type: entity
beta1
The fibre angle of layer 1.
Type: double
beta2
The fibre angle of layer 2.
Type: double
birth
The activation time. Valid for config 102 and birthtoggle set to true.
birthtoggle
The optional flag to activate _BIRTH option. Valid for config 102.
Type: Boolean
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
101 – LS-DYNA *INITIAL_FOAM_REFERENCE_GEOMETR
101 – LS-DYNA *INITIAL_FOAM_REFERENCE_GEOMETRY_RAMP
102 – LS-DYNA *AIRBAG_REFERENCE_GEOMETRY
102 – LS-DYNA *AIRBAG_REFERENCE_GEOMETRY_BIRTH
102 – LS-DYNA *AIRBAG_REFERENCE_GEOMETRY_RDT
102 – LS-DYNA *AIRBAG_REFERENCE_GEOMETRY_ID
102 – LS-DYNA *AIRBAG_REFERENCE_GEOMETRY_BIRTH_RDT
102 – LS-DYNA *AIRBAG_REFERENCE_GEOMETRY_BIRTH_ID
102 – LS-DYNA *AIRBAG_REFERENCE_GEOMETRY_RDT_ID
102 – LS-DYNA *AIRBAG_REFERENCE_GEOMETRY_BIRTH_RDT_ID
103 – LS-DYNA *AIRBAG_SHELL_REFERENCE_GEOMETRY
103 – LS-DYNA *AIRBAG_SHELL_REFERENCE_GEOMETRY_RDT
103 – LS-DYNA *AIRBAG_SHELL_REFERENCE_GEOMETRY_ID
103 – LS-DYNA *AIRBAG_SHELL_REFERENCE_GEOMETRY_RDT_ID
104 – LS-DYNA *INITIAL_AIRBAG_PARTICLE_POSITION
201 – Radioss /XREF
202 – Radioss /EREF/SH3N
203 - Radioss /EREF/SHELL
204 - Radioss /EREF/TETRA4
205 - Radioss /EREF/BRICK
206 - Radioss /REFSTA
401 – PAM-CRASH METRIC/ NODES/
402 - PAM-CRASH METRIC/ BAR/
403 - PAM-CRASH METRIC/ MEMBR/
404 - PAM-CRASH METRIC/ TETRA4/
405 - PAM-CRASH METRIC/ SOLID/
406 - PAM-CRASH METRIC/ PENTA6/
407 - PAM-CRASH METRIC/ TETRA10/
Type: unsigned integer
component
The ID of the component the entity is referring to. Valid for config 103, 201-205, and 401-407.
Type: entity
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
elems_table_component
The ID of the component containing the entity elements.
Type: entity
elems_table_elem
The ID of the element for which a reference configuration is defined.
Type: entity
elems_table_n1
The ID of node 1.
Type: entity
elems_table_n2
The ID of node 2.
Type: entity
elems_table_n3
The ID of node 3.
Type: entity
elems_table_n4
The ID of node 4.
Type: entity
elems_table_n5
The ID of node 5.
Type: entity
elems_table_n6
The ID of node 6.
Type: entity
elems_table_n7
The ID of node 7.
Type: entity
elems_table_n8
The ID of node 8.
Type: entity
elems_table_n9
The ID of node 9.
Type: entity
elems_table_n10
The ID of node 10.
Type: entity
filename
The name of the file containing the reference geometry. Valid for config 206 and 401-407.
Type: string
id
The ID of the entity.
idtoggle
The optional flag to activate _ID option. Valid for config 102 and 103.
Type: Boolean
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
internalname
The internal name of the entity.
Type: string
local_node
The list of METRIC NODE IDs. Valid for config 402-407.
Type: entity array
local_node_count
The number of METRIC NODEs. Valid for config 402-407.
local_node_x
The list of x-coordinates of the METRIC NODEs. Valid for config 402-407.
Type: double array
local_node_y
The list of y-coordinates of the METRIC NODEs. Valid for config 402-407.
Type: double array
local_node_z
The list of z-coordinates of the METRIC NODEs. Valid for config 402-407.
Type: double array
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
ndtrrg
The number of time steps taken for an element to restore its reference geometry. Valid for config 101 and birthtoggle set to true.
nid0
The ID of the origin node for the scaling. Valid for config 102 and 103 and birthtoggle set to true.
Type: entity
nitrs
The number of steps from reference to initial state. Valid for config 201 and 206.
nodes_table_node
The ID of the node for which a reference configuration is defined.
Type: entity
nodes_table_x
The x-coordinate of the node.
Type: double
nodes_table_y
The y-coordinate of the node.
Type: double
nodes_table_z
The z-coordinate of the node.
Type: double
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
ramptoggle
The optional flag to activate _RAMP option. Valid for config 101.
Type: Boolean
rdttoggle
The optional flag to activate _RDT option. Valid for config 102 and 103.
Type: Boolean
refgeom_table
The table containing all reference geometry data.
Type: tabular data
refsta_fileformat
The file version defined on the REFSTA card. Valid for config 206.
0 - V5 or later
1 - V4 or previous
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
sx
The scale factor in x-direction. Valid for config 102 and 103 and idtoggle set to true.
Type: double
sy
The scale factor in y-direction. Valid for config 102 and 103 and idtoggle set to true.
Type: double
sz
The scale factor in z-direction. Valid for config 102 and 103 and idtoggle set to true.
Type: double
table_count
The number of lines of refgeom_table.
virtualnodes_coords
The list of temporary node coordinates existing in the METRIC but not in the model. Valid for config 401.
Applicable only on PAM-CRASH config from 401.
Type: double array
virtualnodes_count
The number of temporary nodes existing in the METRIC but not in the model. Valid for config 401.
virtualnodes_id
The list of temporary node IDs existing in the METRIC but not in the model. Valid for config 401.
Type: unsigned integer array
Version History
2021.1
2021.2 - Added new data names internalname and solvername.
