constraints
Unless otherwise specified, data names are accessible in level 3 only.
- alpha
- The field to specify the thermal expansion coefficient. Applicable for config 301.
- alpha_option
- Option to turn on the alpha entry field.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- config
- The configuration of the entity.
- coupling_option
- Option to turn on the coupling selector. Applicable for config 302
- coupling_value
- The option to pick coupling value. Applicable for config 302
- definedentity
- True if the entity is defined, false otherwise.
- distribution_type
- Specified the distribution type for the weights at the coupling nodes. Applicable for config 302.
- dof1
- Select first degree of freedom.
- dof2
- Select second degree of freedom.
- dof3
- Select third degree of freedom.
- dof4
- Select fourth degree of freedom.
- dof5
- Select fifth degree of freedom.
- dof6
- Select sixth degree of freedom.
- free_nodes_option
- Option to turn on the free nodes selector. Applicable for config 302.
- free_nodes_value
- The option to setup treatment method for nodes. Applicable for config 302.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- influence_radius
- The field to enter influence radius.
- influence_radius_option
- Option to turn on the influence radius entry field.
- internalid
- internalname
- The internal name of the entity.
- location_unit_node
- The coupling nodes on which the weight distribution is specified. Applicable for config 302.
- moduleid
- The module ID of the entity.
- name
- The name of the entity.
- orientation
- The system entity that specifies the initial orientation.
- orientation_option
- Option to turn on the orientation entity selector.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- poolid
- The pool number of the entity.
- poolname
- The pool name of the entity.
- reference_entity
- The entity for setting the reference node or the node set containing reference nodes.
- reference_coupling_option
- Option to turn on rotational coupling selector. Applicable for config 302.
- reference_coupling_value
- The minimum diameter for finding a hole when findhole is 1.
- solver_id
- The solver ID of the entity.
- solverkeyword
- The name of the solver keyword.
- solvername
- The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
- surface
- The surface set on which coupling nodes are located.
- surface
- weight_distribution_row_count
- The number of rows for non-uniform distributing couplings. Applicable for config 302.
- weighting_method_option
- Option to turn on the weighting method selector. Applicable for config 302.
- weighting_method_value
- The option to modify the default weight distribution at coupling nodes.
- weights
- The option to enter the weight values. Applicable for config 302.
Version History
2022
