plotcontrols
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
 - Returns non-zero if the entity is set inactive, 0 otherwise.
 - attributesmax
 - The number of attributes owned by this entity.
 - averaging
 - The averaging mode.
 - color
 - The 1-64 color of the entity.
 - color_rgb
 - The RGB color of the entity.
 - complexfilter
 - The complex filter mode.
 - config
 - The configuration of the entity.
 - contour_enable_iso
 - The flag to enable the iso plot.
 - contour_label
 - The flag to enable contour labels to show min/max locations.
 - corner
 - The flag to request corner data.
 - datacomponent
 - The datacomponent corresponding to the datatype specified.
 - datatype
 - The result datatype which is used for plotting.
 - definedentity
 - True if the entity is defined, false otherwise.
 - deformed_scaling_mode
 - The deformation plot scaling mode. Valid value is “Scale Factor”.
 - deformed_scaling_type
 - The deformation plot scaling type. Valid value is “Uniform”.
 - deformed_scale_uniform
 - The deformation plot uniform scale factor.
 - deformed_undef_display_mode
 - The undeformed shape display mode.
 - id
 - The ID of the entity.
 - ids
 - The entity IDs (nodes, elements, components) which are used for result plotting.
 - include
 - The ID of the include file the entity is organized in.
 - includeid
 - internalid
 - internalname
 - The internal name of the entity.
 - layer
 - The layer corresponding to the datatype specified.
 - moduleid
 - The module ID of the entity.
 - name
 - The name of the entity.
 - omega_t
 - The phase value.
 - outputsuppressed
 - Returns non-zero if the entity is set "do not export", 0 otherwise.
 - poolid
 - The pool number of the entity.
 - plot
 - The plot state indicating whether it is plotted or not.
 - poolname
 - The pool name of the entity.
 - resolved
 - The system in which the result values are transformed to.
 - solver_id
 - The solver ID of the entity.
 - solverkeyword
 - The name of the solver keyword.
 - solvername
 - The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
 - system
 - The system ID which the result values are transformed to.
 - tensor_color_by_mode
 - The tensor arrow color by mode.
 - tensor_format
 - The tensor plotting format. Valid value is Component.
 - tensor_scale
 - The tensor arrow size scaling factor.
 - tensor_show_normal_prefix
 - The flag to show the tensor normal value’s prefix.
 - tensor_show_normal_values
 - The flag to show the tensor normal values.
 - tensor_show_shear_prefix
 - The flag to show the tensor shear value’s prefix.
 - tensor_show_shear_values
 - The flag to show the tensor shear values.
 - tensor_size_scaling_mode
 - The tensor size scaling mode.
 - txy
 - The flag to display tensor XY component.
 - tyz
 - The flag to display tensor YZ component.
 - tzx
 - The flag to display tensor ZX component.
 - value_format
 - The numeric format for vector or tensor values.
 - value_precision
The numeric precision for vector or tensor values. Valid values are integers in the range of 0 to 12.
 - vector_color_by_mode
 - The color mode for the vector arrow.
 - vector_scale
 - The vector size scaling factor.
 - vector_size_scaling_mode
 - The vector arrow size scaling.
 - vector_show_prefix
 - The flag to show vector value’s prefix.
 - vector_show_values
 - The flag to show vector values.
 - vres
 - The flag to display vector plot resultant.
 - vx
 - The flag to display vector plot x component.
 - vy
 - The flag to display vector plot y component.
 - vz
 - The flag to display vector plot z component.
Version History
2021.2
