materials
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
cardimage
The name of the assigned card image.
Type: string
cardimagetype
The type of the assigned card image.
Type: string
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
density
The density of the material. This is only available for "core" solver templates routinely maintained by Altair.
Type: double
encrypted
True if the entity is encrypted, false otherwise.
Type: Boolean
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
isinlibrary
True if the material is in a connected library.
Type: Boolean
librarycomment
The comment when saving to the material library.
Type: string
libraryentityid
The material library entity ID associated to the material.
Type: string
libraryname
The material library name from which the material was loaded.
Type: string
libraryrevision
The material library revision associated to the material.
Type: string
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
poissonsratio
The Poisson's ratio of the material. This is only available for "core" solver templates routinely maintained by Altair.
Type: double
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
youngsmodulus
The Young's modulus of the material. This is only available for "core" solver templates routinely maintained by Altair.
Type: double
Version History
2019 - Added new data names density, poissonsratio and youngsmodulus.
2019.1 - Added new data names isinlibrary, librarycomment, libraryentityid, libraryname and libraryrevision.
2020 - Added new data name color_rgb.
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
