freebodysections
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
0 - FBD load
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
elemidlist
The element ID list.
Type: entity array
entityids
The entity ID list.
Type: entity array
entitytype
The type of the entity.
2 - Elements
80 - Cross section
fbdgroupid
The ID of the freebodygroup the entity belongs to.
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
internalname
The internal name of the entity.
Type: string
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
nodeidlist
The node ID list.
Type: entity array
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
resolve
Resolve in the chosen system type:
0 - Analysis system
1 - Global system
2 - User system
Type: string
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
system
The system ID when resolve is 2.
Type: entity
summationpoint
The symmation coordinates when summationpointtype is 2.
Type: triple double
summationpointtype
The symmation location:
0 - Centroid
1 - Node
2 - Position
Type: triple double
summationnode
The symmation node ID when summationpointtype is 1.
Type: entity
Version History
2019.1
2020 - Added new data names color_rgb and elemidlist.
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names fbdgroupid, internalname, and solvername.
