tables
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
cardimage
The name of the assigned card image.
Type: string
cardimagetype
The type of the assigned card image.
Type: string
cellvalue
The value at a specific row and column. Valid for hm_getvalue query only.
Type: string
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
columndatatype
The data type for a specific column. Valid for hm_getvalue query only.
Type: integer
columndatatypename
The data type name for a specific column. Valid for hm_getvalue query only.
Type: string
columndescription
The description for a specific column. Valid for hm_getvalue query only.
Type: string
columnentitytype
The entity type for a specific column if that column is of type entity. Valid for hm_getvalue query only.
Type: integer
columnlabel
The label for a specific column. Valid for hm_getvalue query only.
Type: string
columns
The number of columns in the table.
Type: integer
config
The configuration of the entity.
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
internalname
The internal name of the entity.
Type: string
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
rows
The number of rows in the table.
Type: integer
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
Version History
2020 - Added new data name color_rgb.
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
