memberjoints
Unless otherwise specified, data names are accessible in level 3 only.
_baseFlags
The base flag of the entity.
Type: unsigned integer
_representations
The representations of the entity.
Type: entity array
_representations_functionalrepresentation
The functional representations of the entity.
Type: entity array
_representations_geometricrepresentation
The geometric representations of the entity.
Type: entity array
_representations_solverrepresentation
The solver representations of the entity.
Type: entity array
_subType
The sub type of the entity.
Type: string
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
1 - Skeleton
connectingmember
The list of member IDs connected to the legs of the member joint.
1 - Skeleton
Type: unsigned integer array
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
internalname
The internal name of the entity.
Type: string
jointlegs
The number of legs associated with the member joint.
jointlocation
The location of the blob of the member joint with respect to the global axis.
Type: triple double
legcoordtable
The tabular attribute defining the leg coordinates table.
Type: tabular
legendoffset
The array of the end offset of each leg from the joint location.
Type: triple double array
legstartoffset
The array of the start offset of each leg from the joint location.
membersection
The list of member section IDs associated with the legs of the member joint.
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
primaryrepresentation
The ID of the primary representation.
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
symmetryid
The ID of the symmetry plane.
symmetryparent
The ID of the parent member joint used for symmetry.
Version History
2022
