encryptions
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
apa_license
Option to define APA licensing for encryption.
Type: Boolean
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
data
The encryption key contents.
Type: array of string
datamax
The size of the data array.
Type: integer
date
The encryption time out date.
Type: triple double
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
day
The encryption time out day.
feature_name
The encryption feature to verify.
Type: string
FU_Option
Differentiates the type of encryption key.
true - /KEY/%FUnn. Used for encrypting function cards, where nn is a key digit varied from 01-99.
false - /KEY/%RDnn. Used for encrypting mats/props, where nn is a key digit varied from 01-99.
Type: Boolean
hours
The encryption time out hour.
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
interface_id
The internal ID which permits to encrypt options with a specific header.
internalid
internalname
The internal name of the entity.
Type: string
KeydigitsRD
The key digits for /KEY for Radioss from 1-99.
Type: integer
keyid
The key reference with format xxxxx, with any letter A-Z/a-z and digits 0-9.
Type: string
license_feature
Option to define licensing for encryption.
Type: Boolean
minutes
The encryption time out minute.
module_name
The feature to check out for encryption.
Type: string
moduleid
The module ID of the entity.
Type: integer
month
The encryption time out month.
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
seconds
The encryption time out second.
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
time
The encryption time out.
Type: triple double
time_out_Option
Option to define time out for encryption.
Type: Boolean
unit_costs
The APA licensing cost for encryption.
Type: double
updateflag
Flag to allow update on time out and licensing.
Type: Boolean
year
The encryption time out year.
Version History
2020 - Added new data name color_rgb.
2020.1 - Added new data name solverkeyword.
2021 - Added new data names apa_license, date, day, feature_name, hours, interface_id, keyid, license_feature, minutes, module_time, month, seconds, time, time_out_Option, unit_costs, updateflag and year.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
