subsystems
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
1 - Standard subsystem
2 - Connector subsystem
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
dirty_flag
An indicator of whether the subsystem contents have been changed since its last representation was realized. Valid for hm_getvalue query only.
export_file_parentid
The parent of the file that is used for export. Valid for hm_getvalue query only.
export_filename
The name of the file used for export. Valid for hm_getvalue query only.
Type: string
export_filepath
The location of the file used for export. Valid for hm_getvalue query only.
Type: string
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
instance
The instance the entity has been created from. Valid for hm_getvalue query only.
Type: entity
internalid
internalname
The internal name of the entity.
Type: string
isinlibrary
Indicates if the entity is in the currently connected library.
Type: Boolean
library_comment
The comment used to save the entity in the library.
Type: string
library_entityid
The unique identifier used to save the entity in the library.
Type: string
library_name
The name of the library where the entity is saved.
Type: string
library_revision
The library revision of the entity in the library.
Type: string
major_revision
The major revision of the entity in the library.
Type: string
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
parentSubsystem
The parent of the subsystem. Valid for hm_getvalue query only.
Type: entity
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
rep_alias
The alias/key of the currently active representation. Valid for hm_getvalue query only.
Type: string
rep_filename
The file name of the currently active representation. Valid for hm_getvalue query only.
Type: string
repDefinitionNames
The representation definitions of the subsystem. Valid for hm_getvalue query only.
Type: string array
repDefinitionNamesSaved
The representation definitions of the subsystem that have been saved. Valid for hm_getvalue query only.
Type: string array
repDefinitionNamesTabularCount
The number of representation definitions of the subsystem. Valid for hm_getvalue query only.
repRealizationNames
The representation realizations of the subsystem. Valid for hm_getvalue query only.
Type: string array
repRealizationsNamesSaved
The representation realizations of the subsystem that have been saved. Valid for hm_getvalue query only.
Type: string array
repRealizationNamesTabularCount
The number of representation realizations of the subsystem. Valid for hm_getvalue query only.
repRealizations
The representaiton realizations of the subsystem. Valid for hm_getvalue query only.
Type: entity array
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
study_revision
The study revision of the entity in the library.
Type: string
subsystemslinkedto
The subsystems that the connectors inside are linked to.
Type: entity array
unique_id
The unique ID of the entity.
Type: string
Version History
2020
2020.1 - Added new data name solverkeyword.
2021 - Removed private data names connector_filter, connectors_attachment, connectors_general, connectors_subsystem, granular_filter, granular_filter_beamsections, granular_filter_elements, granular_filter_loads, granular_filter_nodes, granular_filter_systems, granular_filter_vectors, granular_mode, granular_mode_beamsections, granular_mode_elements, granular_mode_loads, granular_mode_nodes, granular_mode_systems, and granular_mode_vectors.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
