optidscreens
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
autobuck
BUCK - Turn on the buckling adjustment
NOBUCK - Turn off the buckling adjustment
Type: string
autolevel
The normalized threshold value for Auto, with values ranging from 1-5 (ON), and 0 (OFF).
Type: integer
autotoggle
0 - Auto off
1 - Auto on
Type: Boolean
cfailuremaxc
The maximum number of constraints to be retained for Cfailure.
Type: integer
cfailurethreshold
The normalized threshold value for Cfailure.
Type: double
cfailuretoggle
0 - CFailure off
1 - CFailure on
Type: Boolean
cogmaxc
The maximum number of constraints to be retained for Cog.
Type: integer
cogthreshold
The normalized threshold value for Cog.
Type: double
cogtoggle
0 - Cog off
1 - Cog on
Type: Boolean
CompMaxc
Maximum number of constraints to be retained for Comp.
Type: integer
CompThreshold
Normalized threshold value for Comp.
Type: double
CompToggle
Comp toggle on (1) and off (0) state.
Type: integer
configname
The solver name of the entity. Valid for hm_getvalue query only.
Type: string
cstrainmaxc
The maximum number of constraints to be retained for Cstrain.
Type: integer
cstrainthreshold
The normalized threshold value for Cstrain.
Type: double
cstraintoggle
0 - Cstrain off
1 - Cstrain on
Type: Boolean
cstressmaxc
The maximum number of constraints to be retained for Cstress.
Type: integer
cstressthreshold
The normalized threshold value for Cstress.
Type: double
cstresstoggle
0 - Cstress off
1 - Cstress on
Type: Boolean
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
DispMaxc
Maximum number of constraints to be retained for Disp.
Type: integer
DispThreshold
Normalized threshold value for Disp.
Type: double
DispToggle
Disp toggle on (1) and off (0) state.
Type: integer
EquaMaxc
Maximum number of constraints to be retained for Equa.
Type: integer
EquaThreshold
Normalized threshold value for Equa.
Type: double
EquaToggle
Equa toggle on (1) and off (0) state.
Type: integer
externalmaxc
The maximum number of constraints to be retained for External.
Type: integer
externalthreshold
The normalized threshold value for External.
Type: double
externaltoggle
0 - External off
1 - External on
Type: Boolean
forcemaxc
The maximum number of constraints to be retained for Force.
Type: integer
forcethreshold
The normalized threshold value for Force.
Type: double
forcetoggle
0 - Force off
1 - Force on
Type: Boolean
fracclmaxc
The maximum number of constraints to be retained for Fracceleration.
Type: integer
fracclthreshold
The normalized threshold value for Fracceleration.
Type: double
fraccltoggle
0 - Fracceleration off
1 - Fracceleration on
Type: Boolean
frdispmaxc
The maximum number of constraints to be retained for Frdisplacement.
Type: integer
frdispthreshold
The normalized threshold value for Frdisplacement.
Type: double
frdisptoggle
0 - Frdisplacement off
1 - Frdisplacement on
Type: Boolean
frequencymaxc
The maximum number of constraints to be retained for Frequency.
Type: integer
frequencythreshold
The normalized threshold value for Frequency.
Type: double
frequencytoggle
0 - Frequency off
1 - Frequency on
Type: Boolean
frerpmaxc
The maximum number of constraints to be retained for Frerp.
Type: integer
frerpthreshold
The normalized threshold value for Frerp.
Type: double
frerptoggle
0 - Frerp off
1 - Frerp on
Type: Boolean
frstrnmaxc
The maximum number of constraints to be retained for Frstrain.
Type: integer
frstrnthreshold
The normalized threshold value for Frstrain.
Type: double
frstrntoggle
0 - Frstrain off
1 - Frstrain on
Type: Boolean
frstrsmaxc
The maximum number of constraints to be retained for Frstress.
Type: integer
frstrsthreshold
The normalized threshold value for Frstress.
Type: double
frstrstoggle
0 - Frstress off
1 - Frstress on
Type: Boolean
frvelomaxc
The maximum number of constraints to be retained for Frvelocity.
Type: integer
frcelothreshold
The normalized threshold value for Frvelocity.
Type: double
frcelotoggle
0 - Frvelocity off
1 - Frvelocity on
Type: Boolean
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
inertiamaxc
The maximum number of constraints to be retained for Inertia.
Type: integer
inertiathreshold
The normalized threshold value for Inertia.
Type: double
inertiatoggle
0 - Inertia off
1 - Inertia on
Type: Boolean
internalid
internalname
The internal name of the entity.
Type: string
lamamaxc
The maximum number of constraints to be retained for Lama.
Type: integer
lamathreshold
The normalized threshold value for Lama.
Type: double
lamatoggle
0 - Lama off
1 - Lama on
Type: Boolean
massfracmaxc
The maximum number of constraints to be retained for Massfrac.
Type: integer
massfracthreshold
The normalized threshold value for Massfrac.
Type: double
massfractoggle
0 - Massfrac off
1 - Massfrac on
Type: Boolean
massmaxc
The maximum number of constraints to be retained for Mass.
Type: integer
massthreshold
The normalized threshold value for Mass.
Type: double
masstoggle
0 - Mass off
1 - Mass on
Type: Boolean
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
strainmaxc
The maximum number of constraints to be retained for Strain.
Type: integer
strainthreshold
The normalized threshold value for Strain.
Type: double
straintoggle
0 - Strain off
1 - Strain on
Type: Boolean
StressMaxc
Maximum number of constraints to be retained for Stress.
Type: integer
StressThreshold
Normalized threshold value for Stress.
Type: double
StressToggle
0 - Stress off
1 - Stress on
Type: Boolean
volumefracmaxc
The maximum number of constraints to be retained for Volumefrac.
Type: integer
volumefracthreshold
The normalized threshold value for Volumefrac.
Type: double
volumefractoggle
0 - Volumefrac off
1 - Volumefrac on
Type: Boolean
volumemaxc
The maximum number of constraints to be retained for Volume.
Type: integer
volumethreshold
The normalized threshold value for Volume.
Type: double
volumetoggle
0 - Volume off
1 - Volume on
Type: Boolean
Version History
2017.1 - Added new data names autolevel, autotoggle, cfailuremaxc, cfailurethreshold, cfailuretoggle, cogmaxc, cogthreshold, cogtoggle, cstraingtoggle, cstrainmaxc, cstrainthreshold, cstressmaxc, cstressthreshold, cstresstoggle, externalmaxc, externalthreshold, externaltoggle, forcemaxc, forcethreshold, forcetoggle, fracclmaxc, fracclthreshold, fraccltoggle, frdispmaxc, frdispthreshold, frdisptoggle, freqtoggle frequencymaxc, frequencythreshold, frerpmaxc, frerpthreshold, frerptoggle, frstrnmaxc, frstrnthreshold, frstrsmaxc, frstrsthreshold, frstrstoggle, frevelomaxc, frevolothreshold, frevolotoggle, inertiamaxc, inertiathreshold, inertiatoggle, lamamaxc, lamathreshold, lamatoggle, massfracmaxc, massfracthreshold, massfractoggle, massmaxc, massthreshold, masstoggle, strainmaxc, strainthreshold, straintoggle, volumefracmaxc, volumefracthreshold, volumefractoggle, volumemaxc, volumethreshold and volumetoggle.
2020 - Added new data name autobuck.
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
