geometricrepresentations
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- boundingboxlowercorner
- The coordinates of the lower corner of the box in the global system.
- boundingboxuppercorner
- The coordinates of the upper corner of the box in the global system.
- boxdimensions
- The length (along x axis), width (along y axis) and height (along z axis) of the box.
- collectioncentroid
- The coordinates of the centroid of the entities found within the box.
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- config
- The configuration of the entity.
- definedentity
- True if the entity is defined, false otherwise.
- entitycollection
- The IDs of the entities bound by the box.
- excludeentities
- The IDs of the entities to exclude from the box.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- internalname
- The internal name of the entity.
- intersectioncords
- The intersection cords of the entitycollection and the bounding box.
- name
- The name of the entity.
- moduleid
- The module ID of the entity.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- parentrepresentation
- The parent representation if the entity was created from a symmetry.
- poolid
- The pool number of the entity.
- poolname
- The pool name of the entity.
- solver_id
- The solver ID of the entity.
- solverkeyword
- The name of the solver keyword.
- solvername
- The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
- systemaxis
- The values of the 3x3 matrix that orients the local coordinate system of the box at the lower corner expressed in the global axis system.
Version History
2021
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
2022 - Added new data names entitytype>, intersectioncords, and parentrepresentation.
