blocks
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
cardimage
The name of the assigned card image.
Type: string
cardimagetype
The type of the assigned card image.
Type: string
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
internalname
The internal name of the entity.
Type: string
localmax
The maximum coordinates in the local system. Valid for hm_getvalue query only.
Type: triple double
localmaxi
The maximum i-coordinate in the local system.
Type: double
localmaxj
The maximum j-coordinate in the local system.
Type: double
localmaxk
The maximum k-coordinate in the local system.
Type: double
localmin
The minimum coordinates in the local system. Valid for hm_getvalue query only.
Type: triple double
localmini
The minimum i-coordinate in the local system.
Type: double
localminj
The minimum j-coordinate in the local system.
Type: double
localmink
The minimum k-coordinate in the local system.
Type: double
max
The maximum coordinates in the global system. Valid for hm_getvalue query only.
Type: triple double
maxi
The maximum i-coordinate in the global system.
Type: double
maxj
The maximum j-coordinate in the global system.
Type: double
maxk
The maximum k-coordinate in the global system.
Type: double
min
The minimum coordinates in the global system. Valid for hm_getvalue query only.
Type: triple double
mini
The minimum i-coordinate in the global system.
Type: double
minj
The minimum j-coordinate in the global system.
Type: double
mink
The minimum k-coordinate in the global system.
Type: double
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
system
Pointer to the coordinate system.
Type: pointer
systemid
The ID of the system used to orient the block.
Type: integer
Version History
2020 - Added new data name color_rgb.
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
