mechanisms
Unless otherwise specified, data names are accessible in level 3 only.
- activejoints
 - The joints belonging to the mechanism.
 - activesuppressed
 - Returns non-zero if the entity is set inactive, 0 otherwise.
 - attributesmax
 - The number of attributes owned by this entity.
 - childbodiesalllocked
 - A flag indicating if the bodies of secondary mechanisms are all locked to the current mechanism.
 - childdofs
 - The DOFs locked in the relation between parentbody and lockedchildbodies.
 - childmechanism
 - The child/secondary mechanism of the mechanism.
 - color
 - The 1-64 color of the entity.
 - config
 - The configuration of the entity.
 - constraints
 - The constraints belonging to the mechanism.
 - definedentity
 - True if the entity is defined, false otherwise.
 - enabled
 - The enabled flag.
 - id
 - The ID of the entity.
 - ignoredjoints
 - The joints belonging to the mechanism that are ignored and not used for positioning.
 - include
 - The ID of the include file the entity is organized in.
 - includeid
 - internalid
 - lockedchildbodies
 - The child bodies belonging to the mechanism that are locked to the mechanism.
 - mcon_label
 - Set to 1 when a coupler type of constraint is present in the model and the mechanism joint export will have ID fields.
 - moduleid
 - The module ID of the entity.
 - move_xsec
 - Import/export of move xsec in mechanism and dummy export format.
 - name
 - The name of the entity.
 - orphanbodies
 - The bodies belonging to the mechanism.
 - outputsuppressed
 - Returns non-zero if the entity is set "do not export", 0 otherwise.
 - parentbody
 - The main body that drives the child/secondary mechanism.
 - parentmechanism
 - The parent mechanism of the mechanism.
 - poolid
 - The pool number of the entity.
 - poolname
 - The pool name of the entity.
 - referenceposition
 - The position entity with the current orientation of the mechanism.
 - solver_id
 - The solver ID of the entity.
 - solverkeyword
 - The name of the solver keyword.
Version History
2020 - Added new data names color_rgb, mcon_label and move_xsec.
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
