standard
Unless otherwise specified, data names are accessible in level 3 only.
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
beamsect_dim1
The first parameter definition value for standard sections, 0 otherwise. Type: double
beamsect_dim2
The second parameter definition value for standard sections, 0 otherwise. Type: double
beamsect_dim3
The third parameter definition value for standard sections, 0 otherwise. Type: double
beamsect_dim4
The fourth parameter definition value for standard sections, 0 otherwise. Type: double
beamsect_dim5
The fifth parameter definition value for standard sections, 0 otherwise. Type: double
beamsect_dim6
The sixth parameter definition value for standard sections, 0 otherwise. Type: double
beamsect_dim7
The seventh parameter definition value for standard sections, 0 otherwise. Type: double
beamsect_dim8
The eighth parameter definition value for standard sections, 0 otherwise. Type: double
beamsect_dim9
The ninth parameter definition value for standard sections, 0 otherwise. Type: double
beamsect_dim10
The tenth parameter definition value for standard sections, 0 otherwise. Type: double
beamsect_dim11
The eleventh parameter definition value for standard sections, 0 otherwise. Type: double
beamsect_dim12
The twelvth parameter definition value for standard sections, 0 otherwise. Type: double
beamsect_dim13
The thirteenth parameter definition value for standard sections, 0 otherwise. Type: double
collector
Pointer to the collector that owns the element.
Type: pointer (levels 2, 3 and 4)
config
The configuration of the entity.
2 - Standard beam sections
Fillcolor
The color the beam section uses for display of solid regions.
Type: integer
Flags
The optimization flag.
Type: integer
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
internalname
The internal name of the entity.
Type: string
Linecolor
The color the beam section uses for display of lines.
Type: integer
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
OrientationOrigin0
The y component of the beam section origin.
Type: double
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
sectiontype
The non-zero beamsection type for standard sections, or 0 for non-standard sections. Type: integer
setid
The ID of the beam section collector owning the entity.
Type: integer
solverid
The solver ID for standard sections. Type: integer
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
standard_angle
Orientation of the section in 90 degree increments. Type: integer
standard_ParameterInitials
Pointer to the initial values of the parameters. Type: pointer
standard_ParameterMaxima
Pointer to the maximum allowed values of the parameters. Type: pointer
standard_ParameterMinima
Pointer to the minimum allowed values of the parameters. Type: pointer
standard_subtype
The subtype of the standard section, defined by the solver. Type: string
standard_type
The type of the standard section. Type: integer
standard_type_counter
The number of parameters defining the section. This quantity is implied by the type. Type: integer
TorsionFactor
The torsion factor of the beam section.
Type: double
WarpingFactor
The warping factor of the beam section.
Type: double
Version History
2020 - Added new data names beamsect_dim10, beamsect_dim11, beamsect_dim12 and beamsect_dim13.
2020.1 - Added new data name solverkeyword.
2021.2 - Added new data names internalname and solvername.
