temperatures
Unless otherwise specified, data names are accessible in level 3 only.
engineering_type
The engineering type of load. Engineering loads act on set entities. Valid values are:
0 - Classic load
7 - Thermal engineering load
Type: unsigned integer
The following data names are available for both classic and engineering loads:
attributesmax
The number of attributes owned by this entity.
collector
Pointer to the collector that owns the load.
Type: pointer (levels 2, 3, and 4)
config
The configuration of the entity.
5 - Temperature
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
entityid
The ID of the entity the load is attached to.
Type: integer
entitytype
The type of the entity to which the load is applied.
  • 1 - node
  • 2 - elem
  • 3 - comp
  • 10 - set
  • 27 - point
Type: integer
entitytypename
The string type of the entity to which the load is applied.
  • nodes
  • elems
  • comps
  • sets
  • points
Type: string
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
internalname
The internal name of the entity.
Type: string
set
Pointer to the set when the load is applied to a set.
Type: pointer
moduleid
The module ID of the entity.
Type: integer
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
type
The solver dependent type code for the entity.
Type: integer
typename
The solver dependent type name for the entity.
Type: string
The following data names are available for classic loads:
baselocation
The coordinates where the load on a component or set should display. Valid for hm_getvalue query only.
Also used to convert the load vector components into local values for non-rectangular coordinate systems.
Type: triple double
baselocationx
The x-coordinate where the load on a component or set should display.
Type: double
baselocationy
The y-coordinate where the load on a component or set should display.
Type: double
baselocationz
The z-coordinate where the load on a component or set should display.
Type: double
component
Pointer to the component when the load is applied to a component.
Type: pointer
curveid
The ID of the curve defining the load magnitude when a curve has been used to define the load.
Type: integer
inputsystem
Pointer to the reference system.
Type: pointer
inputsystemid
The ID of the reference system.
Type: integer
location
The ID of the node where the load is applied. Valid for hm_getvalue query only.
Type: entity
mappedid
The ID of the original load on geometry.
Type: integer
node
Pointer to the node when the load is applied to a node.
Type: pointer
temperature
The value of the temperature load.
Type: double
xscale
The x scale or time scale of the load curve when a curve has been used to define the load.
Type: double
The following data names are available for engineering loads:
distribution_table_count
The number of rows of a non-uniform engineering load.
field
The field entity that stores the tabular load data.
Type: entity
location_unit_element
The elements for which the data is stored in the table for a non-uniform engineering load.
Type: entity array
location_unit_node
The nodes for which the data is stored in the table for a non-uniform engineering load.
Type: entity array
resultant_magnitude
The resultant scalar component of the load vector in the global coordiante system.
Type: double
The following data names are available for ADVC engineering loads:
constraint_type
Flag to indicate that temperature is retained from the previous process. This is valid for temperature load when type is 3.
Type: Boolean
distribution
The distribution type:
0 - Uniform
1 - Non-uniform
expanded_form_flag
Flag to export loads on nodes.
Type: Boolean
load_step_flag
Flag to indicate if the load step ID needs to be attached to the load. This is valid for temperature load when type is 1.
Type: Boolean
load_step_id
The ID of the referred loadstep.
Type: entity
magnitude
The temperature value.
Type: double
prev_bc
Flag to hold previously applied boundary conditions.
Type: Boolean
The following data names are available for LS-DYNA, engineering loads:
box_region_def
The box ID.
Type: entity
curveid
The load curve ID.
Type: entity
dyn_relax_evolve_fn
The load curve ID during the dynamic relaxation phase.
Type: entity
exempt_node_dyn_rel_temp_sf_evolve_fn
The load curve ID for exempted nodes during the dynamic relaxation phase.
Type: entity
exempt_nodes
The node set ID containing nodes that are exempted from the imposed temperature.
Type: entity
exempt_node_scaled_temp
Type: double
exempt_node_temp
The temperature of exempted nodes (default 0.0).
Type: double
exempt_node_temp_sf_evolve_fn
The load curve ID for exempted nodes.
Type: entity
magnitude
The temperature at node or node set (default 1.0).
Type: double
scaled_temp
The scaled temperature (default 0.0).
Type: double
thk_shell_surf_temp
The thick thermal shell surface where the temperature will be applied.
-1 – Lower surface of thermal shell element
0 – Middle surface of thermal shell element (default)
1 – Upper surface of thermal shell element
Type: integer
The following data names are available for Nastran engineering loads:
nas_tempbc_type
STAT - Constant temperature boundary condition
TRAN - Time-varying temperature boundary condition
Type: Boolean
The following data names are available for Nastran and OptiStruct engineering loads:
distribution
0 - Uniform
1 - Non-uniform
magnitude
The temperature.
Type: double
os_t1
The temperature at the lower surface of shell elements.
Type: double
os_t2
The temperature at the upper surface of shell elements.
Type: double
os_tempp1_flag
The temperature unit flag for TEMPP1:
0 - Thermal gradient
1 - Surface temperature
Type: integer
os_tprime
The effective linear thermal gradient.
Type: double
The following data names are available for OptiStruct engineering loads:
expanded_form_flag
Type: Boolean
The following data names are available for Radioss engineering loads:
curveid
The ID of the curve defining the time function identifier.
Type: entity
displayname
The text for the title entry.
Type: string
distribution
The INITEMP flag:
0 - Initial temperature/node group
1 - Initial temperature/node
magnitude
The ordinate scale factor for fct_ID (default 1.0).
Type: double
rad_sensor_id
The ID of the sensor entity.
Type: entity
rad_tstart
The start time.
Type: double
rad_tstop
The stop time (default 10^30).
Type: double
xscale
The abscissa (time) scale factor for fct_IDT (default 1.0).
Type: double
Version History
2020 - New support for engineering loads. Added new data names displayname, distribution, distribution_table_count, engineering_type, expanded_form_flag, field, location, location_unit_element, location_unit_node, nas_tempbc_type, os_t1, os_t2, os_tempp1_flag, os_tprime, rad_sensor_id, rad_tstart, rad_tstop and resultant_magnitude.
2020.1 - Added new data name solverkeyword.
2021 - Added new data names constraint_type, load_step_flag, load_step_id and prev_bc. New ADVC support.
2021.1 – Added new data names for LS-DYNA engineering loads: box_region_def, curveid, dyn_relax_evolve_fn, exempt_node_dyn_rel_temp_sf_evolve_fn, exempt_node_scaled_temp, exempt_node_temp, exempt_node_temp_sf_evolve_fn, exempt_nodes, magnitude, scaled_temp, and thk_shell_surf_temp.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
