pyramid13
Unless otherwise specified, data names are accessible in level 3 only.
aspect
The element aspect ratio.
Type: double
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
centerx
The x coordinate of the element centroid.
Type: double
centery
The y coordinate of the element centroid.
Type: double
centerz
The z coordinate of the element centroid.
Type: double
collector
Pointer to the collector that owns the element.
Type: pointer (levels 2, 3 and 4)
config
The configuration of the entity.
213 - pyramid13
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
internalname
The internal name of the entity.
Type: string
largestfacearea
The area of the largest element face.
Type: double
longestside
The longest element edge length.
Type: double
maxangle
The maximum interior angle.
Type: double
minangle
The minimum interior angle.
Type: double
moduleid
The module ID of the entity.
Type: integer
node1 - node5
Pointers to the element nodes.
Type: pointer
nodecount
The number of nodes for the element. Valid for hm_getvalue query only.
Type: integer
nodes
The list of nodes for the element. Valid for hm_getvalue query only.
Type: entity array
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
property
Pointer to the property assigned to the entity.
Type: pointer
propertyid
The ID of the property assigned to the entity.
Type: integer
propertyidflag
1 if a property is assigned directly to the entity, 0 otherwise.
Type: integer
shortestside
The shortest element edge length.
Type: double
skew
The element skew angle.
Type: double
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
type
The solver dependent type code for the entity.
Type: integer
typename
The solver dependent type name for the entity.
Type: string
volume
The volume of the element.
Type: double
warpage
The element warpage.
Type: double
Version History
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
