rbe3
Unless otherwise specified, data names are accessible in level 3 only.
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
centerx
The x coordinate of the element centroid.
Type: double
centery
The y coordinate of the element centroid.
Type: double
centerz
The z coordinate of the element centroid.
Type: double
collector
Pointer to the collector that owns the element.
Type: pointer (levels 2, 3 and 4)
config
The configuration of the entity.
56 - rbe3
dependentcoeff
The dependent coefficient/weighting factor.
Type: double
dependentdof
The dependent node degrees of freedom, consisting of the values 1-6.
Type: integer
dependentnode
Pointer to the dependent node.
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
dofs
The degrees of freedom at the dependent node, consisting of the values 1-6.
Type: integer.
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
internalname
The internal name of the entity.
Type: string
independentcoeffs
Pointer to the independent coefficients.
independentcoeffsmax
The number of independent coefficients.
Type: integer
independentdofs
Pointer to the independent degrees of freedom.
independentdofsmax
The number of independent degrees of freedom.
Type: integer
independentnodes
Pointer to the independent nodes.
independentnodesetcoeffs
independentnodesetidofs
independentnodesets
Pointer to the independent node sets attached to the RBE3 elements.
independentnodesmax
The number of independent nodes.
moduleid
The module ID of the entity.
Type: integer
nodecount
The number of nodes for the element. Valid for hm_getvalue query only.
Type: integer
nodes
The list of nodes for the element. Valid for hm_getvalue query only.
Type: entity array
nset
Type: integer
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
rx
Boolean values for rotation Rx of the independent node sets.
Type: Boolean
ry
Boolean values for rotation Ry of the independent node sets.
Type: integer array
rz
Boolean values for rotation Rz of the independent node sets.
Type: integer array
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
tx
Boolean values for translation Tx of the independent node sets.
Type: integer array
ty
Boolean values for translation Ty of the independent node sets.
Type: integer array
type
The solver dependent type code for the entity.
Type: integer
typename
The solver dependent type name for the entity.
Type: string
tz
Boolean values for translation Tz of the independent node sets.
Type: integer array
wt
Weight factors of nodes belonging to the independent node sets.
Type: double array
Version History
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names independentnodesets, independentnodesetcoeffs, independentnodesetidofs, nset, rx, ry, rz, tx, ty, tz, and wt.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
