SWLDPRM, GSMOVE
Bulk Data Entry Maximum number of times GS for CWELD (PARTPAT or ELPAT format) or GS/GE for CSEAM is moved in cases when not all auxiliary points have projections onto the patch of shells.
Parameter Values Description
GSMOVE Integer ≥ 0
Default = 0
Maximum number of times GS for CWELD (PARTPAT or ELPAT format), GS/GE for CSEAM, or GS/GA/GB for CFAST is moved in cases when not all auxiliary points have projections onto the patch of shells.
