SWLDPRM, GSTOL
Bulk Data Entry Presently it only applies to CSEAM. Maximum distance between GS-SA, GS-SB, GE-EA and GE-EB for CSEAM.
Parameter Values Description
GSTOL Real ≥ 0.0
Default = 0.0
If the distance is greater than GSTOL, then the connector element will not be generated and an error will be issued.
If GSTOL is set to 0.0, the program will skip the checking of GSTOL.
