PARAM, KISSSOFT
Bulk Data Entry Controls the creation of the condensed stiffness matrix in an ASCII file to be used by the KISSsoft program.
Parameter Values Description
KISSSOFT <YES, NO>
YES
The required condensed stiffness matrix is output to the .kss ASCII file.
NO (Default)
The required condensed stiffness matrix is not output to the .kss ASCII file.
  1. The CMSMETH Bulk Data Entry with METHOD field set to GUYAN should be used with PARAM,KISSSOFT,YES.
