PARAM, RICARDO
Bulk Data Entry Controls the creation of the condensed flex body modes and full diagonal mass matrix to the .op2 file to be used by VALDYN from Ricardo Software.
Parameter Values Description
RICARDO <YES, NO>
YES
The required condensed flex body modes and full diagonal mass matrix are output to the .op2 file.
NO (Default)
The corresponding condensed flex body modes and full diagonal mass matrix are not output to the .op2 file.
  1. The CMSMETH Bulk Data Entry with METHOD field set to CBN should be used with PARAM,RICARDO,YES.
