PARAM, THCNTPEN
Bulk Data Entry Controls the penalty factor used in thermal contact analysis.
| Parameter | Values | Description |
| THCNTPEN | <AUTO, LOW, HIGH> | PARAM,
THCNTPEN controls the penalty factor used in
- Theoretically, while higher conductivity values enforce a perfect conductor, excessively high values may result in poor conditioning of the conductivity matrix. In such cases, it may be beneficial to reduce the value of conductivity, or use conductivity based contact clearance and pressure.
- This parameter influences the KCHTC field of the PCONTHT Bulk Data Entry and the KAHT field of the PGAPHT Bulk Data Entry.
