PARAM, SORTCON
Bulk Data Entry Controls the output of violated constraints to the .out file from an optimization.
Parameter Values Description
SORTCON <Integer>
Default = 20
This parameter controls the output of violated constraints to the .out file (and to screen).
By default, the 20 most violated constraints are printed in a separate table and sorted by percentage violation. This behavior can be modified with PARAM, SORTCON, N; where N is the number of constraints to be printed. (N = 0 disables this feature).
