*feinputwithdata2 - IDRULES_SKIP
The ID Manager import options specified in the Import tab are written to the command file as a string array, associated with a *feinputwithdata2 command. The easiest way to produce this array is to import a file using the desired parameters, and then to examine the created string array in the resulting command file.
HyperMesh Tcl Modify Command
IDRULES_SKIP
By default, ID manager rule information is read and imported. Usage of this string will prevent that information from being read.
Version History
14.0.120
